Feature Type blocks the preview window
david0711
(@david0711)
I am not able to figure out how to remove the feature type legend from the preview window. I can't see the model? It covers about one third of the preview window.
Your help would be much appreciated.
Dave
Opublikowany : 24/08/2020 7:03 am
RE: Feature Type blocks the preview window
Along the bottom of the preview window are a series of tick boxes, travel, Retractions, Unretractions, Shell and Legend.  Untick legend.
Also what resolution is your monitor ?  1/3 seems very excessive, its pretty small on the 2 machines I run the software on.
Opublikowany : 24/08/2020 8:05 am
david0711
(@david0711)
@neophyl
Thanks for your rapid response. I don't have the view that your have since my computer display is running a 150 percent. I am using wide screen tv for a monitor. I am just checking out prusa slicer and will also run it on other computers running a normal display. I found a work around I found out that the letter L on the keyboard will remove the legend. Some programs compensate for the changed display size and some don't. It is not a big deal since I will be running prusa slicer on other computers.
Thanks again for your reply.
Dave
Opublikowany : 24/08/2020 9:57 am
towlerg
(@towlerg)
Don't forget you can move the model by holding down the left button,  pan the bed by holding down the right button and zoom in and out with the wheel.
Opublikowany : 24/08/2020 12:29 pm
