Feature Request - Slice Warning for Object Not Flat on Bed
JOHNE
(@johne)
Slicer has so many (not useful) warnings that I often ignore them. The one warning that I could really use is a warning that the object that I just flipped to sit on the print bed is not quite sitting flat on the bed and will result in a spaghetti print.
Example: I had one today that looked like it was on the bed, but and I should have been suspicious when the brim didn't appear on the slice. Spaghetti print. This happens a lot to me because .stl files often have a weird orientation and you need to flip them. The slicer looks like it is snapping them to the bed but often they are not actually sitting on the bed. I need to get in the habit of using the sit flat function, flip over the bed and select the bottom of the object but I am an impatient person...
This topic was modified 6 months temu by JOHNE
Opublikowany : 21/11/2025 10:47 am
_KaszpiR_
(@_kaszpir_)
RE: Feature Request - Slice Warning for Object Not Flat on Bed
https://github.com/prusa3d/PrusaSlicer/issues/new/choose
Opublikowany : 21/11/2025 11:36 am
JOHNE
(@johne)
Done
Opublikowany : 21/11/2025 12:23 pm
