Feature request, overextrusion due to infill/perimeter overlap
messickmatt
(@messickmatt)
Hello, I'm not sure if this issue already exists, or what the process is for submitting a feature request.
I am using PrusaSlicer with a custom built large scale printer.  As the movement is less precise, I am using a relatively large infill\perimeter overlap of 40%.  When using infill over short gaps, this extra length causes an overextrusion and a buildup of plastic.  For large areas with longer infill passes, the error is less noticeable.
I was wondering if a feature could be added to scale the effective extrusion multiplier based on the length of the infill pass and the percent overlap.  For example, if filling a gap of 10mm, with an infill overlap of 0.1mm, the extrusion multiplier on that pass only would be (10mm)/(10mm+0.1mm+0.1mm) = 0.9804
Postato : 07/01/2023 10:28 pm
RE: Feature request, overextrusion due to infill/perimeter overlap
This is a user to user forum.  For issue reports and feature requests you need to go to the Prusa Slicer github.  That is located https://github.com/prusa3d/PrusaSlicer/issues
Please follow the template instructions when opening a new issue.  Also its worth searching with as many potential keywords as you can think of, both the open and closed issues before opening a new one as there are over 2300 open issues already and 6200+ closed ones
Postato : 07/01/2023 10:48 pm
