Feature Request: Maximum/Minimum Layer Height for Adaptive Variable Layer Height Function
I think an option to set limits on the adaptive layer height function would be useful. An example:
Adaptive Layer Height
- Maximum Layer Height: 0.2 mm
- Minimum Layer height:0.08 mm
The slicer would do its thing, but any layers rougher than 0.2 mm would be reduced to 0.2 mm. Likewise any layers finer than 0.08 would be changed to 0.08 mm.
Opublikowany : 20/04/2020 6:40 am
RE: Feature Request: Maximum/Minimum Layer Height for Adaptive Variable Layer Height Function
already present, in "printer configuration" (i use another language so not sure is exact name", extruder, "limit layer height" or do you mean a different, separate value only for adaptive variable layer height function ?
Opublikowany : 20/04/2020 7:15 am
