Feature request - increase skirt distance automatically when adding a brim!
powershell
(@powershell)
too many times have I used the stock settings and just added a brim with the tick box and i just hit slice and export only to realize the brim goes outside of the skirt.  It hasnt messed up any major prints yet, but it seems like that setting should know to dynamically change when a brim is added.  Or at least it should recognize the outer layer of the brim as the outside of the object.
Opublikowany : 10/04/2020 2:55 pm
1 ludzie polubili
martin.b23
(@martin-b23)
RE: Feature request - increase skirt distance automatically when adding a brim!
Just adding a +1 on this topic.
Opublikowany : 13/04/2020 4:54 pm
Joey
 Joey
(@joey-2)
+1
Or at least display a pop-up message when you enable brim, and skirt is enabled.
Mk3 - 1X
Mk3S - 2X
2021 Hyundai Palisade
Wife - 1X
Opublikowany : 14/04/2020 11:36 am
Guys posting here is not going to get you any traction on this.  You need to post over on github https://github.com/prusa3d/PrusaSlicer/issues   check if someone has already created the feature request before starting one and if there is one you can add your +1's there.
Opublikowany : 14/04/2020 11:50 am
1 ludzie polubili
