Feature Request: Hollow, holes and remove internal support
debra.k
(@debra-k)
I'd like to see Prusa slicer able to hollow out an object and ability to place holes in an objects.  I have been using a program called Asura 3d, that came with the Peoploy Moai to hollow out and place holes and then export the result as a stl to slice in Prusa Slicer.
It would  be nice to be able to do all of this in Prusa Slicer.
Also an option to remover internal supports on hollowed out objects would be appreciated
Debra
Opublikowany : 21/11/2019 10:22 am
RE: Feature Request: Hollow, holes and remove internal support
Even though the prusa blog post mentions posting feature requests over here its really the wrong place.  The devs rarely ever respond to stuff here.  If you want your feature request to be seen, post it over on Prusa's github page at https://github.com/prusa3d/PrusaSlicer/issues
Once you post there it gets a proper tracking number and goes on the system for consideration.
Opublikowany : 21/11/2019 10:28 am
debra.k
(@debra-k)
Thanks
Opublikowany : 21/11/2019 10:31 am
I've been able to hollow out parts using Prusa Slicer.  Pretty simple to do using modifiers.
Opublikowany : 22/11/2019 1:33 am
1 ludzie polubili
