[Cerrado] Feature Request
Marcel Isler
(@marcel-isler)
Feature Request
It looks like PrusaSlicer 2.3 has made great strides forward, but there are a couple of things I think it is missing:
1. User defined solid infill angles.  In S3D, I can specify the solid infill angles and I set them to 45, -45, 0, 90 which gives much better coverage over infill and against oddly shaped perimeters.  It quite drastically reduces the amount of layers needed before a flat top surface is achieved, especially over low density infill.
2. Allow for heating and cooling parameters to change based on layer height.  It seems odd that those parameters can't be set... for example, increasing the bed temp gradually for large flat prints can help keep the print from lifting up on the corners.
3. Let modifiers also change cooling amount.  It would be great if I could place a box into the upper arch of a circular cutout and have additional cooling in that area to prevent the overhang from curling up.
4. Separate speed for perimeters and solid infill over support.  Bridging speeds aren't always feasible when you have curved lines on top of support.  It would be great if the perimeter speed could be slower to make sure the curve lays down properly while the solid infill can be much faster.
That's about it, I hope at least some of these will find their way into a future version.
Grats on the progress, definitely impressed with how far it has come.
Best Answer by Neophyl:
This is a user to user forum.  All feature requests and issues need to be made at the Prusa Slicer github repository located here https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc
I think you will find that most if not all of your requests have already been made there though.  Please do a search before opening new duplicate ones.  There are over 1600 open issues.
Temperature can already be set by layer.  You can either use some custom gcode to set things by layer mathematically or the easier method is to insert gcode at the layer you want in a similar manner to the colour change function.  As that allow you to simply right click the layer slider icon and then insert custom gcode.
Respondido : 20/03/2021 6:52 pm
RE: Feature Request
Respondido : 20/03/2021 7:06 pm
Marcel Isler me gusta
