Failed processing of the output_filename_format template.
Taylor Johnson
(@taylor-johnson)
Hello,
I am getting this error when trying to export the Gcode from an STL file. What does this mean and how do I fix it? I've never seen this error before.
Failed processing of the output_filename_format template. Parsing error at line 1: Non-integer index is not allowed to address a vector variable.{input_filename_base}_{nozzle_diameter[initial_tool]}n_{layer_height}mm_{printing_filament_types}_{printer_model}_{print_time}.gcode
Thanks in advance.
Respondido : 12/07/2023 1:58 am
Taylor Johnson
(@taylor-johnson)
RE: Failed processing of the output_filename_format template.
I figured out that I have to 'slice' the STL model prior to extracting the Gcode. Not sure if others are experiencing this but that's what fixed the issue for me.
Respondido : 12/07/2023 6:16 am
1 les gusta
