Extrusion width 100% is less than 100%
[Rozwiązany] Extrusion width 100% is less than 100%
dval
 dval
(@dval)
I am printing with 0.8mm nozzle. I set my extrusion width to 100% for infill.
I am receiving the following error:
Infill_extrusion_width=0.5 mm and is too low to be printable at a layer height 0.5 mm
How can I tell the slicer that 100% of 0.8 is 0.8, not 0.5?
Opublikowany : 30/04/2022 1:32 am
dval
 dval
(@dval)
RE: Extrusion width 100% is less than 100%
100% width is height.
Opublikowany : 30/04/2022 1:39 am
Swiss_Cheese
(@swiss_cheese)
Stop using percentages and start using mm.
Good luck
Swiss_Cheese
The Filament Whisperer
Opublikowany : 30/04/2022 1:47 am
Dvaal if you read the tooltip for that option then yes percentages are based off your layer height. Not your nozzle size. It’s why the profiles for Prusa printers are always specified in mm.
Opublikowany : 30/04/2022 6:57 am
