Extrusion multiplier
OB1
 OB1
(@ob1)
This also applies to my MK3S: I've found that when I print a single walled cube/cylinder calibration object with Prusament PLA using all default Prusament PLA filament/print/printer settings in Prusaslicer (except for vase mode turned on), the wall thickness is between 0.4 to 0.42 - no where close to the expected 0.45mm thickness for a 0.4 nozzle and 0.2mm layer height.
Is it expected for Prusament PLA default settings to not be calibrated for extrusion multiplier? If so, what's the point of the default settings?
Postato : 18/05/2023 10:31 pm
OB1
 OB1
(@ob1)
RE: Extrusion multiplier
Previous post applies to both MK4 and MK3S. It got moved and I can't edit it.
Thanks for help!
Postato : 19/05/2023 2:15 am
