Extruder Change on Different objects behavior
Seb_K
(@seb_k)
Hi there,
i’m playing with multi-material and extruder changes. It does well for now but i would like to do somthing special and i guess it is not so easy …
Actually i print two objects in two different colors with two extruders the normal behavior is :
Layer 1 Object 1 Extruder 1 M600 Object 2 Extruder 2
Layer 2 Object 2 Extruder 2 M600 Object 1 Extruder 1
Layer 3 Object 1 Extruder 1 M600 Object 2 Extruder 2
Etc …
Seems to be optimized and logical but the result on what i really want is not so good … The way to improve my render would be to do :
Layer 1 Object 1 Extruder 1 M600 Object 2 Extruder 2 M600
Layer 2 Object 1 Extruder 1 M600 Object 2 Extruder 2 M600
Layer 4 Object 2 Extruder 2 M600 Object 1 Extruder 1
Layer 5 Object 1 Extruder 1 M600 Object 2 Extruder 2
Etc …
Is there any way to change that in the slicer or am i mandatory to play in gcode in text mode ??
Thank at all 🙂
Respondido : 23/11/2021 4:45 pm
Seb_K
(@seb_k)
RE: Extruder Change on Different objects behavior
Thanks for all that links but my english is too bad to be sure to find what i want ?! May be somting easly to handle ?
Respondido : 23/11/2021 7:24 pm
Prusa Slicer optimises for the fewest filament changes.  If you wish to optimise for layer cooling it might be easier to add a pause ( G4 ) at layer change.
Respondido : 23/11/2021 7:47 pm
Seb_K
(@seb_k)
Not for that cooling thing. In my scheme
First objectiis in yellow as text surrounded by black on the first layer, i would like the second layer start again with the text in yellow for have something thicker and less able to be damaged by the black color ...
Respondido : 23/11/2021 7:55 pm
Seb_K
(@seb_k)
Anyway nothing is your links is helpfull.
Noway to change print object order in the slicer, I guess i have to do it manually :/
Respondido : 23/11/2021 9:57 pm
