Extruder Change on Different objects behavior
Hi there,
i’m playing with multi-material and extruder changes. It does well for now but i would like to do somthing special and i guess it is not so easy …
Actually i print two objects in two different colors with two extruders the normal behavior is :
Layer 1 Object 1 Extruder 1 M600 Object 2 Extruder 2
Layer 2 Object 2 Extruder 2 M600 Object 1 Extruder 1
Layer 3 Object 1 Extruder 1 M600 Object 2 Extruder 2
Etc …
Seems to be optimized and logical but the result on what i really want is not so good … The way to improve my render would be to do :
Layer 1 Object 1 Extruder 1 M600 Object 2 Extruder 2 M600
Layer 2 Object 1 Extruder 1 M600 Object 2 Extruder 2 M600
Layer 4 Object 2 Extruder 2 M600 Object 1 Extruder 1
Layer 5 Object 1 Extruder 1 M600 Object 2 Extruder 2
Etc …
Is there any way to change that in the slicer or am i mandatory to play in gcode in text mode ??
Thank at all 🙂
RE: Extruder Change on Different objects behavior
Thanks for all that links but my english is too bad to be sure to find what i want ?! May be somting easly to handle ?
Prusa Slicer optimises for the fewest filament changes. If you wish to optimise for layer cooling it might be easier to add a pause ( G4 ) at layer change.
Not for that cooling thing. In my scheme
First objectiis in yellow as text surrounded by black on the first layer, i would like the second layer start again with the text in yellow for have something thicker and less able to be damaged by the black color ...
Anyway nothing is your links is helpfull.
Noway to change print object order in the slicer, I guess i have to do it manually :/
