Exporting sliced geometry as STL
NM
 NM
(@nm-2)
is it somehow possible, to export a sliced part as geometry. STEP or STL would be great. So i can run some calculations and maybe do some optimisations on the geometry?
/regards
Thomas
Respondido : 11/02/2020 8:02 am
Stefan Maurer
(@stefan-maurer)
RE: Exporting sliced geometry as STL
im also interested in this topic.  I want the sliced geometry of the part for an FDM simulation. Thomas have you found any solution yet or is there someone else with a solution?
Regards
Stefan
Respondido : 21/12/2022 7:49 pm
Snuffleupagus
(@snuffleupagus)
Miembro
You can Export Toolpaths as .obj that's the sliced version of your project.
Respondido : 21/12/2022 9:52 pm
NM
 NM
(@nm-2)
i didn't found anything usefull yet. But maybe the .obj is at least a good starting point. But it does not produce a good closed volume that you could use for a simulation directly.
Regards
Thomas
Respondido : 22/12/2022 8:13 am
