RE: Export with blockers
If you can export just the support blockers from Rhino either as individual STL files or a single STL with all the blockers there, you can load the STL as a support blocker in Plicer. I haven't tried something similar in my 3D package of choice (FreeCAD) myself so I don't know if there will be any translation errors, but I would think that if your 3D object STL and the support blocker STL file share the same origin point the loaded blocker should line up properly.
See my (limited) designs on:
Postato : 06/01/2020 5:56 pm
