Export plate as STL/Obj including supports doesn't work?
TeachThePrints
(@teachtheprints)
In PS 2.7.4, the "Export plate as STL/Obj including supports" is always greyed out, meanwhile the "Export plate as STL/Obj" button does work.
What needs to be done to be able to use the export including supports option? The model is sliced and ready to be exported.
Prusa Mini FW6.2.4
Veröffentlicht : 09/05/2024 10:19 am
Eef
 Eef
(@eef)
RE: Export plate as STL/Obj including supports doesn't work?
This option is only available with resin printers.
So what I do is, install a resin printer, give supports in there. Export as stl.
Change to your own printer + import.
Veröffentlicht : 10/05/2024 8:56 pm
