export detailed printing info by CLI
Hello,
after slicing, some beautiful and useful information are calculated (/estimated), i.e. time and percentage of support material, solid infill, etc... I refer to whater is in the yellow circled box of my screenshot.
I'd like to extract all those values from command lines, is it possible?
All I can find is to export the gcode by the command "--export-gcode" , but the gdoce file only contains the summarized info in the green circle of the screenshot, such as estimated printing time, and filament used.
thank you.
(the screenshot gets cutted, i added the two zoom in part)
You want to extract data from the generate gcode preview legend window?
AFAIR this is not available in summarized format, you'd have to somehow process G0/G1 commands yourself with additional comments to detect if the perimeter or infill is generated.
What could be useful is https://help.prusa3d.com/article/list-of-placeholders_205643
RE: export detailed printing info by CLI
Yep, that was my request. I would have liked to get the already calculated values, instead of recalculate them myself from the gcode. But thanks anyway, that was useful information.
You could ask for a feature request in PrusaSlicer github repo to have that data available as a placeholders or added to the commented section at the end of the gcode.
