eSun ePA-CF, Carbon Fibre Slicer Profile.
Page 8 / 9
RE: eSun ePA-CF, Carbon Fibre Slicer Profile.
Yup.  They droop on the windshield of a car.
Posted by: @joantabb
I have had PLA Items  go soft in the sun...
or on a radiator
could higher temperature be the issue
PLa has a low glass transition temperature
Posted : 25/11/2021 12:07 pm
DKGuffe
(@dkguffe)
I was talking about the eSun Nylon HT CF, it's supposed to be 170MPA at 150 degrees, short term up to 180 degree C, and it's pliable and soft like licorice at 20 degree C after a couple of weeks.
Posted : 26/11/2021 1:54 am
Good luck!
I hope the supplier sorts this.
Posted : 28/11/2021 10:39 pm
marcusone
(@marcusone)
Great post and reading. thanks everyone, espcially @jmone
However, all the profile attachments appear to have been removed 🙁 can they be posted again, or linked to somewhere more permanent?
Posted : 31/03/2022 3:02 pm
jmone
(@jmone)
Here it is again
3DBenchy_ePA-CF
Posted : 01/04/2022 3:43 am
TheReverend
(@thereverend)
My settings for ePA-CF: dry @70c>12hrs (from bag, or 24Hrs if left out); 280c; 80c PEI (textured) plate, nano-adhesive or glue stick if needed; no fan; 40-60mm/s speed; use enclosure; 0.4mm hardened nozzle; 0.2-0.32mm layers (adaptive); tree supports (with support interfaces); 20-100% infil; optimize-wall order (less retraction = less clogs). I pre-heat the build surface & extruder for 5-min or so for this stuff, as well as print directly from dryer.
~ Qidi X-Plus, stock high-temp extruder, with upgraded Qidi hotend & buildplate; SUNLU 3D Printer Filament Dryer Box S2 ~
Posted : 30/01/2023 5:08 pm
mog
 mog
(@mog-2)
isn't Nylon suposed to be printed without fan? why are you using 30% fan? (honest question, noob here)
Posted : 13/03/2023 4:27 pm
Magprint3d
(@magprint3d)
Hi guys!
My prints are also coming soft, just immediately after printing with this same filament.
I have dried my spool for over 24h and benchu comes out great, but it is maleable even with only one hand, as if it was some king of super hard TPU.
I have been told this material needs 50ºC ambient temperature, is this correct?
Is there any news on this topic? thanks!
This post was modified 3 years ago 2 times by Magprint3d
Posted : 20/06/2023 12:33 pm
Bob Renegade
(@bob-renegade)
It looks like eSun manufacture(d) two totally different ePA-CF, having different parameters, including strength.
One is this: https://www.esun3d.com/epa-cf-product/
(also on the second picture)
Another one - see the first picture.
Even on the spools they have different recommended print temperatures, but that is not all, companies selling it - specify totally different other parameters.
The question is, are these two filaments the same, or the first one indeed have superior parameters, compared to the second one?
Which one you got?
Posted by: @jmone
Posted by: @sembazuru
Isn't ePA a polyamide, which is Nylon? Do Nylons print with the same profiles (temperatures, linear advance K value, volumetric flows, cooling, etc) as PETG? Wouldn't Taulman Bridge be a better starting point?
(I'm asking because I honestly don't know...)
Yes the PA include Nylon but the eSun ePA range have a lower printing temp that straight Nylon (so it has been modified somehow) and it is similar to PETG (hence why I started with that one as a base profile).  The only stats I have on the eSun ePA-CF is from their info:
Characteristics:
- Environmentally friendly, Nylon based, 20% carbon fiber;
- Printing smoothly, odorlessness, matte finish printing effect;
- High Strength, High Rigidity, Good Toughness, Wear Resisting, Fitting to 3D print industrial parts;
- HD T Top 160℃, then suitable for the high temp occasion;
- Compared with Nylon, it has lower shrink rate and distortion, high accuracy without warped edge;
- Good flame resistance, Flame-retardant level: UL94-V2;
- Stainless steel nozzle shall be needed instead of quick-wear bronze nozzle when using CFRPA filament.
- Print Temp: 240-260
- Bed Temp:  80
- Density: 1.24
- Heat Distortion: 120c
- Melt Flow Index: 10 g/10min
- Tensile Stregth: 75 MPa
- Elongation at Break: 26%
- Flexural Strength: 122 MPa
- Flexural Modulus: 5160 MPa
- IZOD Impact Strength: 12 kJ/m3
I also have a spool of Dupont Zytel (PA 6) and it too is tough as nails but much more expensive and I print that at 270c and used the Poymaker PC-Max (for some reason I've forgotten but probably it was the closest at the time for Print Temp) as the basis for my tweaks on this filament.
This post was modified 2 years ago 2 times by Bob Renegade
Posted : 21/10/2023 5:57 pm
Magprint3d
(@magprint3d)
Mine is the first one
Posted : 23/10/2023 12:12 pm
Bob Renegade
(@bob-renegade)
(I know, my post is confusing as to which filament is the "first", and whish one is the "second", because I listed the products in one order and the pictures went in reverse order; but when I realized that, the forum would not let me to edit the post, so...)
Which one is yours, the "240-260" one?
Posted : 25/10/2023 7:39 pm
Magprint3d
(@magprint3d)
Correct, the one with the clear spool.
Posted : 26/10/2023 7:38 am
jmone
(@jmone)
All of mine have also been the clear spool, and they still rock!
Posted : 26/10/2023 10:56 am
Magprint3d
(@magprint3d)
I always thought my bad results are caused by incorrect printing parameters... care to share your printing profile for this material?
Posted : 30/10/2023 10:55 am
jmone
(@jmone)
See my 1st April 2022 post (not a joke!).  It has the 3MF of the Benchy that has the settings.
Posted : 05/12/2023 6:44 am
KyleWilliams1024
(@kylewilliams1024)
So, I was reading this thread as I have some of this material but haven't used it yet. I have the first one on the clear spool, with a max temp of 260 suggested.
For context, those of you that have suggested settings, etc, which version do you have?
Thanks
Posted : 15/12/2023 3:34 pm
gigifux
(@gigifux)
Good evening everyone. I would like to ask your opinion on this problem I am having. Look carefully at these two pieces. They were printed with my MK4 using the same GCODE, no changes between one print and another. Filament dried in the oven at 80° for at least 24 hoursPlate 80°Nozzle 275° first layer - 280° the following onesFilling 30°Perimeters 10 - lower 10 - upper 10Fan 0
Until the other day the prints were perfect then suddenly the prints became "wrinkled" in the external perimeters. Thinking that it could be the nozzle (V6 in hardened steel) worn out I replaced it with a new identical one. But the result did not change. I even tried to change the filament thinking that it could be a problem related to a defective spool but nothing, no change. The left piece as you can see has rough perimeters, until the other day they were perfect.What is even stranger is that the problem occurs only with this filament. For example, printing the Esun EPA NATURAL filament the prints were and continue to remain perfect. In your opinion, what could have happened.Opinions and suggestions?Thanks to those who will help megigi
Posted : 12/10/2024 4:29 pm
Scott Jones
(@scott-jones)
Did anyone ever find out the difference between the 2 specs for this filament, I am coming to use this myself and I found the technical data sheet, thinking it was for the stuff I had, turns out mine is the clear roll from the pictures and the TDS looks to be from the other picture with the higher print temperature. https://www.esun3d.com/uploads/eSUN_ePA-CF-Filament_TDS_V4.0.pdf
I did read somewhere that eSun released a pa6-cf that was supposed to be stronger but only came in a 750g spool (at the same price as the 1kg) but this is still showing as 1kg, only reason I bring it up is the TDC mentions 6/66 copolymer so my instincts is this is related to the other type?
I am also currently going through some test prints, its looking great at the moment, impressed with the visual quality, however I am finding it delaminating / layer adhesion is not great. I can run my finger/nail down the side of the test print and the layers start coming away from each other.
Print speed is at 25, wall thickness 1.2mm / 6 line count, have gone done .12 , .175 and .2 layer height, no cooling, and a range of temperatures, ranging from 260 through to 290 I have now run this stuff through a dryer for 36+ hours @70 - its why I am assuming I am getting verry little stringing
my next step is to bake this in an oven for a few hours, I am waiting for another test print to finish before I do that though.
has anyone printed this stuff at 290? - I am finding at this higher temperature the layer adhesion is actually much stronger, when snapping the test parts the breaks are no longer clean along the layer line. but everywhere I read says it shouldn't need to go this high and from the research I have done says that printing at this temp can actually have negative consequences with shorter hardware lifespan, clogging, and in some instances actually cause material weakness.
I am somewhat new to 3d printing and attempting to use this stuff in a project, learning a lot each day but I am wondering if anyone can suggest things to try to get better layer adhesion, my current test has reduced the temperature back down to 265 and have increased the layer height along with a few other minor tweaks
A final question I have too, I have read that the bridge ability for this material is on average 5-10mm, with dialling in the settings this could be optimised to 20-30mm, can anyone chime in here, I see @jmone has done a test print for another user here, noticed the bridge did not go too well without supports.
Posted : 13/01/2025 4:31 am
Scott Jones
(@scott-jones)
sorry to double post, been doing more research and still having issues with the prints, the latest test print was the worst yet, I had changed minor settings like slowing down the initial layer, but the major ones was layer height and temp to 265 - really didnt work, overhang failed, bridging was near enough non existent and layer separation was all over the place from the print alone.
just took another look at amazons listing for this stuff and they recommend 260-290, I found another technical data sheet relating to eSuns ePA6-CF so the one I linked above is not for that (eSun calls their PA6 ePAHT-CF) their printing specs are all over the place, their website contradicts the TDC, other resellers have different specs too and the spool label is different to all of these.
I have contacted eSun to see if I can get any clarification on the subject.
Posted : 13/01/2025 2:00 pm
Bul
 Bul
(@bul)
Hi!
I've read through this topic, but still need advice on how can I increase print quality.
I'm using eSun ePA-CF, the transparent reel version. Bridging is poor which I can live with, I'm triying to avoid designing bridges on PA-CF models.
I also experience a lot of unnecessary protrusions building on the model. They can grow past the top layer, so the print head bumps into them. Sidewall surface look is also poor. Bulging is prominent around seams. I've tried to increase retraction and use avoid crossing perimeters while printing a single object, but they did not help. Then I started to do a proper calibration and increase drying temp and duration.
I have the following gear:
Wanhao Box2 filament dryer
Original Prusa i3 MK3S+ & Nozzle X 0.6mm
PrinterBox Prusa-box
Buildtak Nylon+ buildplate
Filament is in the dryer for more than three days. Temp is 90C, and the built-in sensor of Wanhao box displays 18% RH.
I've tried to print right from the filament drier, but was worried that the filament absorbs too much water in free air, so I moved the reel into the enclosure. Chamber temp gradually increases from 45C to 55C during prints.
I have calibrated the filament the following way.
I've set the nozzle a bit further away from the buildplate, and print the first layer 240C, so the nylon does not stick too much to the Buildak buildplate.
Extrusion multiplier is 90% (flow is set to 95% by Prusa gcode), so the calibration cube wall thickness is accurate, as far as I can measure it with an "analog" caliper which works to one fractional digit. I'm waiting for better tools to arrive.
I've done a K-factor calibartion as well, which resulted in 0.05 for this ePA-CF.
The temp tower looks like as on the attached pictures. I cannot observe any trend or sweet spot between 230C and 280C...
The fan shroud samples on the picture were printed on 260C and 270C. Both of them have a lot of bulging around fan inlet and also around top mounting ear corners.
Can You recommend any idea, where to look for any improvement?
This post was modified 5 months ago by Bul
Posted : 27/09/2025 10:53 am
Page 8 / 9
