eSun ePA-CF, Carbon Fibre Slicer Profile.
Page 3 / 8
marto
(@marto)
RE: eSun ePA-CF, Carbon Fibre Slicer Profile.
No I am trying 50% speed will see where it goes
Posted : 08/09/2020 5:53 pm
marto
(@marto)
Edit , nope it under extrude big time.
I have to disassembly this thing and clean it roughly . I will be switching the heatbreak with titanium one and stock fan with more powerful sunion.
Any other advice, printed ok on 265 C then cloging started and I raised temps in order to run this thing , but still no success, the spool is inside eBox for the last 4 days. Any chance I did overcooked this thing
Posted : 08/09/2020 7:27 pm
jmone
(@jmone)
Nope, it is pretty easy to print for me (no harder than PLA).  I do have the Mosquito Magnum Hot End and a 0.4mm Tungsten Carbide Nozzle.  You don't want to go any smaller than 0.4mm and you need a good nozzle.  What is your nozzle made from?  It it is Brass then the CF will chew it out.  If it is hardened than you will need to raise you print temp (as it is worse at conducting heat).  The Tungsten Carbide Nozzles are really really good, high thermal transfer properties and very low wear.  There is a thread on these somewhare...
Posted : 08/09/2020 8:46 pm
marto
(@marto)
My setup is , stock V6 hot end with SS heat break and e3d hardened nozzle 0.4
I upped the temps up to 279 C, no luck, I think the noctua fan is not cooling enoughfor 270 C+
First test was with 265 and went OK
then I noticed it is freezing and upped the temps, but no luck.
When from factory bag and before using you data I used some Nylon profile edited and it was printing ok
Posted : 08/09/2020 10:03 pm
jmone
(@jmone)
Unscrew the Nozzle and have a look?  The only think I've noticed (but it has not caused an issue for me), is the dry CF is harder and stiffer than other filaments so maybe it is slipping in the gears on the extruder?  If the Nozzle is clear then maybe tighten it up a bit?
Posted : 08/09/2020 10:16 pm
Flo4Print
(@flo4print)
For information I have printed about 400g of my ePA-CF spool with no issues without drying it, at 250 degres.
Standard E3D V6 hotend except nozzle which is a NozzleX.
MK3S & Fusion 360
Posted : 09/09/2020 9:21 am
marto
(@marto)
@flo-r
speeds , fan settings ?
Posted : 09/09/2020 9:35 am
marto
(@marto)
So having in hand diamond hotend , decided to swap .
1. I had heat creap in the heat break, so my thoughts about weak noktua fan are correct.
2. Did not have enough time tonight , so just printed 40x40 cube in vase mode , the wall is 0.51 mm with 0.95 just like my very first test .
more tests tomorrow, left the filament in a bag with sachet of silicagel
Tomorrow 3 hours in ebox and then tests again , this time I put Nozlle X 0.4 mm
Posted : 09/09/2020 6:05 pm
Flo4Print
(@flo4print)
Posted by: @martin-s66
@flo-r
Printed slow, if I remember well 20-40 mm /s and fan stopped. Like for standard nylon.  (Sorry I am away from my computer to have a look at the profile)
MK3S & Fusion 360
Posted : 09/09/2020 7:16 pm
marto
(@marto)
@flo-r
Open air or enclosed
Posted : 09/09/2020 7:53 pm
Flo4Print
(@flo4print)
Enclosed.
MK3S & Fusion 360
Posted : 09/09/2020 8:50 pm
jmone
(@jmone)
FYI - I test printed the 40mm cube in vase mode using ePA-CF and it was accurate in x/y dimensions better than 0.1mm (both came in at 39.9x mm) just above the base and the Z was 39.8x mm (so better than 0.2mm) but this could be a first layer squash.  The cube did have a twist in it so the top is romboidal with the tension (eg out of square).
Posted : 10/09/2020 2:41 am
marto
(@marto)
@jmone
what about wall thickens, it hsve to be 0.45 , but it is 0.52 mm
The dimensions are 40 +/- 0.2 mm
Posted : 10/09/2020 4:48 am
jmone
(@jmone)
All of my wall thickness are 0.44
Posted : 10/09/2020 5:02 am
marto
(@marto)
So printed with dragon, lower speed about 40 , 20 for outer perimeters and top.
15x15 cube left with cooling 20/40
Filament dryied for 4 hours in Esun ebox
Right no cooling
This post was modified 5 years ago by marto
Posted : 10/09/2020 5:13 pm
marto
(@marto)
15x15 cube top with cooling 20/40,other  no cooling
Filament  for 4 hours in Esun ebox
Right no cooling
Posted : 10/09/2020 5:17 pm
marto
(@marto)
With 0.87 extruder coefficient I got 0.46 wall, that is within the error of my dial caliper .
Now overnight real world part
Posted : 10/09/2020 5:33 pm
jmone
(@jmone)
That extruder coefficient looks oddly small.  Mine is 0.96 and a my Default Extrusion Width is 0.45.
Here is my Ini FWIW
# generated by PrusaSlicer 2.2.0+win64 on 2020-09-10 at 20:55:32 UTC
avoid_crossing_perimeters = 0
bed_custom_model =
bed_custom_texture =
bed_shape = 0x0,250x0,250x210,0x210
bed_temperature = 90
before_layer_gcode = ;BEFORE_LAYER_CHANGE\nG92 E0.0\n;[layer_z]\n\n
between_objects_gcode =
bottom_fill_pattern = rectilinear
bottom_solid_layers = 4
bottom_solid_min_thickness = 0
bridge_acceleration = 1000
bridge_angle = 0
bridge_fan_speed = 60
bridge_flow_ratio = 0.95
bridge_speed = 30
brim_width = 0
clip_multipart_objects = 1
colorprint_heights =
compatible_printers_condition_cummulative = "printer_notes=~/.*PRINTER_VENDOR_PRUSA3D.*/ and printer_notes=~/.*PRINTER_MODEL_MK3.*/ and nozzle_diameter[0]==0.4";"nozzle_diameter[0]!=0.6 and ! (printer_notes=~/.*PRINTER_VENDOR_PRUSA3D.*/ and printer_notes=~/.*PRINTER_MODEL_MK(2.5|3).*/ and single_extruder_multi_material)"
complete_objects = 0
cooling = 1
cooling_tube_length = 20
cooling_tube_retraction = 40
default_acceleration = 1000
default_filament_profile = "Prusament PLA"
default_print_profile = 0.15mm QUALITY MK3
deretract_speed = 0
disable_fan_first_layers = 1
dont_support_bridges = 1
draft_shield = 0
duplicate_distance = 6
elefant_foot_compensation = 0
end_filament_gcode = "; Filament-specific end gcode"
end_gcode = G1 X0 Y210 F7200\nG1 E2 F5000\nG1 E2 F5500\nG1 E2 F6000\nG1 E-15.0000 F5800\nG1 E-20.0000 F5500\nG1 E10.0000 F3000\nG1 E-10.0000 F3100\nG1 E10.0000 F3150\nG1 E-10.0000 F3250\nG1 E10.0000 F3300\n\nM702 C\n\nG4 ; wait\nM104 S0 ; turn off temperature\nM140 S0 ; turn off heatbed\nM107 ; turn off fan\nG1 X0 Y200 F3000 ; home X axis\nM84 ; disable motors
ensure_vertical_shell_thickness = 1
external_perimeter_extrusion_width = 0.45
external_perimeter_speed = 25
external_perimeters_first = 0
extra_loading_move = -25
extra_perimeters = 0
extruder_clearance_height = 25
extruder_clearance_radius = 45
extruder_colour = #FFFF00
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 0.96
fan_always_on = 1
fan_below_layer_time = 20
filament_colour = #FF8000
filament_cooling_final_speed = 3.4
filament_cooling_initial_speed = 2.2
filament_cooling_moves = 4
filament_cost = 50
filament_density = 1.27
filament_deretract_speed = nil
filament_diameter = 1.75
filament_load_time = 0
filament_loading_speed = 28
filament_loading_speed_start = 3
filament_max_volumetric_speed = 8
filament_minimal_purge_on_wipe_tower = 15
filament_notes = ""
filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6"
filament_retract_before_travel = nil
filament_retract_before_wipe = nil
filament_retract_layer_change = nil
filament_retract_length = nil
filament_retract_lift = nil
filament_retract_lift_above = nil
filament_retract_lift_below = nil
filament_retract_restart_extra = nil
filament_retract_speed = nil
filament_settings_id = ePA-CF
filament_soluble = 0
filament_toolchange_delay = 0
filament_type = NYLON
filament_unload_time = 0
filament_unloading_speed = 90
filament_unloading_speed_start = 100
filament_vendor = (Unknown)
filament_wipe = nil
fill_angle = 45
fill_density = 0%
fill_pattern = gyroid
first_layer_acceleration = 1000
first_layer_bed_temperature = 85
first_layer_extrusion_width = 0.42
first_layer_height = 0.2
first_layer_speed = 20
first_layer_temperature = 255
gap_fill_speed = 40
gcode_comments = 0
gcode_flavor = marlin
gcode_label_objects = 0
high_current_on_filament_swap = 0
host_type = octoprint
infill_acceleration = 1250
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0.45
infill_first = 0
infill_only_where_needed = 0
infill_overlap = 25%
infill_speed = 80
inherits_cummulative = ;"Prusament PETG";"Original Prusa i3 MK3S MMU2S Single"
interface_shells = 0
layer_gcode = ;AFTER_LAYER_CHANGE\n;[layer_z]
layer_height = 0.2
machine_max_acceleration_e = 5000,5000
machine_max_acceleration_extruding = 1250,1250
machine_max_acceleration_retracting = 1250,1250
machine_max_acceleration_x = 1000,960
machine_max_acceleration_y = 1000,960
machine_max_acceleration_z = 1000,1000
machine_max_feedrate_e = 120,120
machine_max_feedrate_x = 200,100
machine_max_feedrate_y = 200,100
machine_max_feedrate_z = 12,12
machine_max_jerk_e = 1.5,1.5
machine_max_jerk_x = 8,8
machine_max_jerk_y = 8,8
machine_max_jerk_z = 0.4,0.4
machine_min_extruding_rate = 0,0
machine_min_travel_rate = 0,0
max_fan_speed = 60
max_layer_height = 0.25
max_print_height = 210
max_print_speed = 200
max_volumetric_speed = 0
min_fan_speed = 30
min_layer_height = 0.07
min_print_speed = 15
min_skirt_length = 4
notes =
nozzle_diameter = 0.4
only_retract_when_crossing_perimeters = 0
ooze_prevention = 0
output_filename_format = {input_filename_base}_{layer_height}mm_{filament_type[0]}_{printer_model}_{print_time}.gcode
overhangs = 0
parking_pos_retraction = 85
perimeter_acceleration = 800
perimeter_extruder = 1
perimeter_speed = 45
perimeters = 1
post_process =
print_host =
print_settings_id = 0.20mm QUALITY MK3 - Copy
printer_model = MK3SMMU2S
printer_notes = Don't remove the following keywords! These keywords are used in the "compatible printer" condition of the print and filament profiles to link the particular print and filament profiles to this printer profile.\nPRINTER_VENDOR_PRUSA3D\nPRINTER_MODEL_MK3\n
printer_settings_id = Original Prusa i3 MK3S MMU2S Single - Copy
printer_technology = FFF
printer_variant = 0.4
printer_vendor =
printhost_apikey =
printhost_cafile =
raft_layers = 0
remaining_times = 1
resolution = 0
retract_before_travel = 1
retract_before_wipe = 0%
retract_layer_change = 1
retract_length = 0.8
retract_length_toolchange = 3
retract_lift = 0.6
retract_lift_above = 0
retract_lift_below = 209
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 35
seam_position = rear
serial_port =
serial_speed = 250000
silent_mode = 1
single_extruder_multi_material = 0
single_extruder_multi_material_priming = 0
skirt_distance = 2
skirt_height = 3
skirts = 1
slice_closing_radius = 0.049
slowdown_below_layer_time = 20
small_perimeter_speed = 25
solid_infill_below_area = 0
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0.45
solid_infill_speed = 80
spiral_vase = 1
standby_temperature_delta = -5
start_filament_gcode = "M900 K{if printer_notes=~/.*PRINTER_HAS_BOWDEN.*/}200{elsif nozzle_diameter[0]==0.6}22{else}45{endif} ; Filament gcode"
start_gcode = M115 U3.7.1 ; tell printer latest fw version\nG90 ; use absolute coordinates\nM83 ; extruder relative mode\nM104 S[first_layer_temperature] ; set extruder temp\nM140 S[first_layer_bed_temperature] ; set bed temp\nTx\nM190 S[first_layer_bed_temperature] ; wait for bed temp\nM109 S[first_layer_temperature] ; wait for extruder temp\nG28 W ; home all without mesh bed level\nG80 ; mesh bed leveling\n\nG21 ; set units to millimeters\n\n;go outside print area\nG1 Y-3.0 F1000.0\nG1 Z0.4 F1000.0\n; select extruder\nTc\n; purge line\nG1 X55.0 F2000.0\nG1 Z0.3 F1000.0\nG92 E0.0\nG1 X240.0 E25.0 F2200.0\nG1 Y-2.0 F1000.0\nG1 X55.0 E25 F1400.0
support_material = 0
support_material_angle = 0
support_material_auto = 1
support_material_buildplate_only = 0
support_material_contact_distance = 0.2
support_material_enforce_layers = 0
support_material_extruder = 0
support_material_extrusion_width = 0.35
support_material_interface_contact_loops = 0
support_material_interface_extruder = 0
support_material_interface_layers = 2
support_material_interface_spacing = 0.2
support_material_interface_speed = 100%
support_material_pattern = rectilinear
support_material_spacing = 2
support_material_speed = 50
support_material_synchronize_layers = 0
support_material_threshold = 55
support_material_with_sheath = 0
support_material_xy_spacing = 50%
temperature = 260
thin_walls = 0
threads = 16
thumbnails =
toolchange_gcode =
top_fill_pattern = rectilinear
top_infill_extrusion_width = 0.4
top_solid_infill_speed = 40
top_solid_layers = 0
top_solid_min_thickness = 0
travel_speed = 180
use_firmware_retraction = 0
use_relative_e_distances = 1
use_volumetric_e = 0
variable_layer_height = 1
wipe = 1
wipe_into_infill = 0
wipe_into_objects = 0
wipe_tower = 1
wipe_tower_bridging = 10
wipe_tower_no_sparse_layers = 0
wipe_tower_rotation_angle = 0
wipe_tower_width = 60
wipe_tower_x = 96.9095
wipe_tower_y = 113.488
wiping_volumes_extruders = 70,70
wiping_volumes_matrix = 0
xy_size_compensation = 0
z_offset = 0
Posted : 10/09/2020 9:41 pm
marto
(@marto)
I never checked esteps on prusa, something that I start with other printers, but with PETG and ABS the wall was spot on last time I checked with new filament
Posted : 10/09/2020 9:47 pm
edwardbarrowman
(@edwardbarrowman)
@jmone
Hi there, would you be able to share the filament profile settings and values for glass fiber zytel? I can't seem to find any, Than you!
Posted : 19/09/2020 1:07 am
Page 3 / 8
