[Rozwiązany] Error when slicing
Kimobonbon
(@kimobonbon)
Error when slicing
Hello everyone, I've recently ran into an error while slicing "G-code export to F:\Temp\.15116_0.gcode failed". What confuses me is I don't have an F drive, although I used to.
What I tried:
Restarting computer,
Reinstalling PrusaSlicer,
Making a SUBST link to try and trick PrusaSlicer into thinking it is a real drive, and redirect to C.
None of these have worked. If you have any advice, I'd be happy to take it.
Thanks in advance!
Opublikowany : 02/10/2025 7:20 pm
Kimobonbon
(@kimobonbon)
RE: Error when slicing
I FIXED IT!
What I did: go into system variables then change the User Variables TEMP and TMP to another folder, in my case they were set to F\Temp, so I changed them to G\Temp. Hope this helps anyone with my same issue!
Opublikowany : 04/10/2025 7:25 am
