Error "there is an object with not extrusions in the first layer"
Janetta Rotramel
(@janetta-rotramel)
I am trying to get a gcode for this Black_Dragon.rar file I have already unzipped the files and all looked good but when i tried to get a gcode for the STL file Base_with_footprints_(gargantuan_base) it gives me an error so i right click on the image and click on fix through the netfabb. it says it is fixed so i try to do the export the gcode again and i get the same error, what am i doing wrong..
Veröffentlicht : 14/06/2022 3:09 pm
Please either give us a link to the file or zip it and post it here. (The forum will reject it if not zipped.)
Until then any answer will be a guess - most likely there is a very fine point  projecting beneath the model, a point too fine to print but forcing the slicer to lift the model above the build plate... Hence nothing at the base.
Veröffentlicht : 14/06/2022 4:52 pm
Swiss_Cheese
(@swiss_cheese)
RE: Error "there is an object with not extrusions in the first layer"
@janetta-rotramel
I would urge you not to post the file here, as this section of the forum is for a printer that is not currently available to the public.
I will suggest that you choose a section of the forum that matches your printer type, or go to the PrusaSlicer section and ask your question, you may get more responses that way. Although I'm sure Deim is capable of handling this. it's still best to post in the appropriate area.
Regards
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 14/06/2022 9:41 pm
Thanks @swiss_cheese, this came up on 'Recent Posts' and I didn't notice which forum it was in.
Veröffentlicht : 15/06/2022 1:26 am
