Error message
Michael Pierich
(@michael-pierich)
Error message
Just tried to export two files from stl to gcode, and each said:
Failed processing of the output_filename_format template.Parsing error at line 1: Non-integer index is not allowed to address a vector variable.{input_filename_base}_{nozzle_diameter[initial_tool]}n_{layer_height}mm_{printing_filament_types}_{printer_model}_{print_time}.gcode ^
Do I need to change some settings?  Thanks.
Publié : 29/07/2023 11:09 pm
Hello
(@hello)
RE: Error message
May I ask exactly what your naming the file as it sounds like it's something to do with the name
Publié : 30/07/2023 5:54 am
RE: Error message
It will most likely be the [initial_tool] part of your filename output string as defined in your print profile.  It is expecting an integer in there ie, 0-9.
Publié : 30/07/2023 10:01 am
Michael Pierich
(@michael-pierich)
RE: Error message
What setting should I change for the intial tool value?
Publié : 30/07/2023 7:43 pm
First try deleting  '_{nozzle_diameter[initial_tool]}n' to verify this is the cause.
Then try with '_{nozzle_diameter[0]}' which may be what you are looking for or, in case that 'n' is misplaced try '_{nozzle_diameter[n]}' but I may be misinterpreting the last one.
Publié : 30/07/2023 11:18 pm
Michael Pierich
(@michael-pierich)
RE: Error message
Thanks. But I'm very new at this and have no idea how to do amy of that.
Curious thing us that it was working perfectly, then this. I even re-imstalled.
Publié : 31/07/2023 12:09 am
It is set in Print Settings > Output options
Publié : 31/07/2023 7:18 am
Ken Hammond
(@ken-hammond)
RE: Error message
I am also getting this message after upgrading Prusa Slicer to 2.6.1.  I've been using Prusa Slicer for years.  Here is the full message:
Publié : 07/09/2023 8:17 pm
Michael Pierich
(@michael-pierich)
RE: Error message
I deleted the app and used another slicer for awhile. Re-installed prusaslicer and it then worked. No probs with new release yet.
Publié : 07/09/2023 8:28 pm
jmpage2
(@jmpage2)
RE: Error message
I'm experiencing the same problem and would love some info on how to resolve it short of deleting/re-installing the app.
Publié : 07/09/2023 10:34 pm
rrauenza
(@rrauenza)
RE: Error message
Just change the output filename to:
{input_filename_base}_{layer_height}mm_{printing_filament_types}_{printer_model}_{print_time}.gcode
Removing ...
Publié : 22/11/2023 2:49 am
Muse_Child
(@muse_child)
Membre
RE: Error message
Make sure you slice the model before you try to save the G-code!
If you are going straight to File> Export> Export G-code, you will have this issue, I think that's the first way I learned to export G-codes and I had this issue.
Use the "slice now" button in the lower right-hand corner, then use the same button (it changes to "Export G-code") or the File path to export it after the model has finished slicing.
Publié : 13/03/2024 3:17 pm
