Error filename output
I got this error when when I use the EM variable for the filename.
I thought, that I can use every variable for the filename output. What is the issue here?
best regards
Best Answer by bobstro:
If you're referring to the Print Settings->Output options->Output file->Output filename format, the placeholders should be in square brackets.
Napsal : 11/03/2021 5:40 pm
RE: Error filename output
Napsal : 11/03/2021 8:24 pm
1 lidem se líbí
