Ensuring Object are Flat on the Bed
eager
(@eager)
I'm sorry for having to post this but 1 - I'm on a super tight deadline for this print and 2- I've read replies to a similar post and read many Googled results but the suggestions have not worked in my Prusa Slicer 2.8.1   I've selected Place on Face, I've tried to grab the white right angles but the objects won't move and I've chosen Rotate and then chosen Place on Face and nothing happens. I've exited the Prusa Sliver and tried it all over and no changes. I've powered off my W11 PC and powered back on and still no changes.
It's a file I downloaded as a zipped file which I extracted all and then dragged that .stl file (the bottles) on to the Prusa Slicer bed.
I'd so appreciate any other creative solutions.
Thank you so much.
Opublikowany : 12/11/2024 8:04 pm
JP Guitars
(@jp-guitars)
RE: Ensuring Object are Flat on the Bed
Zip the stl and post so we can have a look
Opublikowany : 12/11/2024 8:05 pm
eager
(@eager)
Hopefully I've zipped this correctly in W10.
Thank you.
Opublikowany : 12/11/2024 8:17 pm
JP Guitars
(@jp-guitars)
You've got the objects grouped, you can tell that by when you click on one they are all selected. In slicer right click on one of the objects, select Split/To Objects
You should then be able to manipulate them as required
Opublikowany : 12/11/2024 8:21 pm
1 ludzie polubili
eager
(@eager)
Got it printed with your help.  Thank you so much!!
Opublikowany : 12/11/2024 10:44 pm
