Ender-6 printing time
XTbe
 XTbe
(@xtbe)
I just started exploring Prusa Slicer for the Ender-6. I selected the built-in profile for Ender-6 (and also found the matching filament) however when I compare this with Cura printing time is so much longer so I was wondering why is the speed so much lower in Prusa while the printer is in fact capable to print with higher speeds?
Does anyone have recommendations / figures for increasing the speed for Ender-6? I suppose they are steered in the screenshot below?
Thank you already for any feedback, much appreciated!
/Tom
Opublikowany : 14/10/2021 12:27 pm
DanAndersen
(@danandersen)
Lets compare 🙂
Hi Tom,
I have the opposite experience with PrusaSlicer after switching from Cura. So let's start with the obvious: Would you be so kind and make a screenshot of your Cura Configuration you are comparing?
Change the "Viewing Profile to "Expert" or "All" and then open the pull-down section of "Speed".  Then we can compare all speeds and acceleration settings you used with Cura.
I am pretty sure there will be significant differences which causes slower speeds in PrusaSlicer.
Good luck 🙂
Daniel
Opublikowany : 14/10/2021 11:43 pm
