Ender 3 pro with cr touch problems
Hi I just moved over from cura 5.4 to prusa slicer 2.6.1
I've got a ender 3 pro with filament runout sensor and a cr touch and when I slice a model and when I put it into my printer its starts the bed leveling but it only stays in one stop
Where in cura it went around the bed
Has anyone got any ideas how I can fix this
Thanks
Veröffentlicht : 16/11/2023 8:53 pm
RE: Ender 3 pro with cr touch problems
So I have been dealing with similar issues where sliced files from Prusa just won't print on my v2 Neo. You might have luck if you slice the same file in prusa and cura, then compare the GCode in Notepad. You might be able to spot the code that works for cura and move it over to prusa.
Veröffentlicht : 16/11/2023 10:25 pm
