Ender 3 presets vanished
Bob
 Bob
(@bob-2)
I own 3 3d printers, a Prusa I3 MK 2.5S, a Prusa Mini, and an Ender 3.  For obvious reasons I use Prusa Slicer for all 3.  Recently I updated to 2.2.0+ and to my distress I discovered nearly all of my presets have vanised and have been replaced by a tiny number of different presets.
Is there any way to get my presets back the way they were?  I liked that I could use the same slicer settings between all 3 of my printers.  I know many believe that layer setting for the Ender 3 should be a multiple of .4, and while there may be some evidence for that, I've had great success using the same layer heights as my Prusa printers.  I often print components for the same project on all 3 of my printers and I've had no problems assembling anything I've printed this way.
I'd really like all my presets for layer height and filament.  Is there any way to do this?  I've tried re-running the configurator and that isn't doing it.
Thanks
-Bob
Opublikowany : 21/12/2020 3:02 am
RE: Ender 3 presets vanished
Before you upgrade, save your presets.  Try to downgrade.
Opublikowany : 21/12/2020 11:28 am
Maurizio
(@maurizio)
Posted by: @bob-2
Thanks
-Bob
In Windows software, usually when you install PrusaSlicer and create profiles a folder is created in this path:  C:\Users\Maurizio\AppData\Roaming\PrusaSlicer      in the folders      "filament" "print" "printer"   paste your setups. Generally, if this folder is not deleted, at each new installation of PrusSlicer the program automatically refers to that path, if it is not displayed, check where it created the folder and update it.
This post was modified 5 years temu 3 times by Maurizio
Opublikowany : 24/03/2021 11:28 am
