End Gcode M117 !!
Patrick.b
(@patrick-b)
End Gcode M117 !!
Hello
since last fmw or even previous one i can't get anymore the text i add on my endgcode with the M117
at the end after the M84 i added the following line
M117 G4 P500 happy day
M300 S440 P200
M300 S660 P250
M300 S880 P300
M300 S1100 P400
and when the printing is done it show up the text but very shortly , before it stay and show on lcd , the hotline prusa advice me to try wit the G4 but still , same issue , and then the name file is showing instead of my text..
did someone have idea ?
thx
Napsal : 15/10/2021 7:33 pm
RE: End Gcode M117 !!
Try:
G4 S0
M117 text, text....
M300 S440 P200
M300 S660 P250
M300 S880 P300
M300 S1100 P400
wbr,
Karl
Posted by: @patrick-b
Hello
M300 S440 P200
M300 S660 P250
M300 S880 P300
M300 S1100 P400
thx
Napsal : 15/10/2021 8:54 pm
Patrick.b
(@patrick-b)
danke karl will ich probieren
Napsal : 15/10/2021 9:10 pm
Patrick.b
(@patrick-b)
hallo,
Well it's not working..same , = txt pop up but then print name stay on screen .. 😭  danke sehr
Napsal : 18/10/2021 1:53 pm
Which printer, which FW version?
On my MK3 with 3.8.1 FW this works fine with this end gcode:
M702 C
G4 S0
M117 turn off nozzle
M104 S0 ; turn off nozzle
G4 S0
M117 going home
G1 X205 Y205; home X Y axis
M84 ; disable motors
M106 S255 ; fan on, hotend cooling
G4 S240 ; keep fan running for 240 seconds to cool hotend and allow the fan to be turned off - adjust to your needs
M107 ; turn off fan. Don't use M106 S1. Some say M107 doesn't work for them but if the hotend is below 70 degrees it should work
M220 S100 ; speed 100%
G4 S0
M117 print finished
M300 S1000 P500 ;First beep
M300 S0 P500 ;Wait
M300 S1000 P1000 ;Second beep
M300 S0 P500 ;Wait
M300 S1000 P1500 ;Third beep
wbr,
Karl
Napsal : 18/10/2021 5:52 pm
Patrick.b
(@patrick-b)
waou this is quit different from original end gcode ! i'll copy all to check
i am on MK bear with 3.10 FW Bear too cause i install the Bearexxa but i don't think it come from FMW bear !!
i'll back to you asap i test it thx again
Napsal : 18/10/2021 7:05 pm
