Dual Extruder setup on PrusaSlicer
Lillian Wilson
(@lillian-wilson)
Mitglied
Hi all, after having many issues withe the slicer software for this printer I have instead decide to use PrusaSlicer. I'm having several problems related to g-code and I don't know how to fix them.
I want to fix,
  • Auto-bed leveling ( it levels itself but doesn't seem to use the values)
    • when I try to get it to mesh bed level with the code it will just probe the print area again
  • Wipe tower purge volumes (because its not a single extruder with a mmu I cant seem to change the purge volumes)
    • I tried changing the Purge Volume Multiplier and it looks like it only helped a little bit.
  • Tool changes (when it changes extruders it switches right on top of the print leaving oozed filament all over it)
    • I tried a custom g-code to make it move and that didn't work either
the printer model is a CreatBot D600 Pro2. I cant find much at all about it online and the slicer for it is modeled after PrusaSlicer (almost a copy and paste kind of thing) so moving to PrusaSlicer was pretty easy and the best choice.
Veröffentlicht : 02/07/2024 4:00 pm
Lillian Wilson
(@lillian-wilson)
Mitglied
RE: Dual Extruder setup on PrusaSlicer
I have fixed the issue 🙂
Veröffentlicht : 15/07/2024 3:26 pm
Hi Lillian,
Could you describe what you did to fix the issue,  for information?
Ah just seen your other post !
https://forum.prusa3d.com/forum/prusaslicer/start-gcode-for-creatbot-dx-plus/#post-716447
Diese r Beitrag wurde geändert Vor 4 hours von JoanTabb
Veröffentlicht : 15/07/2024 3:31 pm
