        don't support bridges.
Ok. We have the "Don't support bridges" option. But how to tell the Slicer how far it should be considered as a bridge?
The structure was designed considering the bridge concept. So, almost all faces have high angles with some bridges. The exceptions are some faces expected to be supported on the top. Although its behavior is correct with very small bridges (it did not support them), PrusaSlicer insists in want to also support those not so bigger bridges (1 mm or 2 mm length).
(from what, I think it could be a good idea an option informing the maximum length we want without supporting a bridge.)
                            Opublikowany : 25/11/2020 2:12 am
                    RE: don't support bridges.
I would post a ticket on GITHUB.
                            Opublikowany : 26/11/2020 11:10 pm
