Do you have to enable adaptive cubic infill somehow
JLTX
 JLTX
(@jltx)
I've tried adaptive cubic infill on boxes, cylinders , spheres, and random objects.  It does not vary near any wall at all, perfectly uniform.  I've tried PrusaSlicer 2.3 and 2.4 alpha.  It never works for me.  Is there another setting I need in addition to make it work?
Support cubic does work a little bit, in that it gets tighter near the top but still way too sparse to bridge.
Posted : 24/04/2021 3:51 am
RE: Do you have to enable adaptive cubic infill somehow
I've played with both. The first key is that you want to set infill density to the maximum you want at the top or sides. The slicer takes care of incrementing from a calculated lower range.
The print also needs to be large enough to see much variation. Here's an Adaptive example.
Posted : 24/04/2021 5:40 am
DaveX liked
Starting with the MAXIMUM infill is key. I usually see little effect if I use infill less than 15%. 40% usually looks good.
Confused the hell out of me, too.
Posted : 24/04/2021 11:47 am
DaveX liked
JLTX
 JLTX
(@jltx)
Ah, that makes sense.  It is scaling down from what you set, not scaling up.  I should have thought of that.  That’s a better approach.  Thanks!
Posted : 24/04/2021 11:56 am
DaveX liked
Dawson
(@dawson)
I was trying to use it for the first time this evening and this thread answered my question of why it didn't seem to be any different than standard cubic when I sliced the model.
Seems like this little tip would be a good thing for prusa to add to the informational popout for adaptive cubic infill?
Posted : 05/09/2024 1:01 am
