Display the time remains for the next color change?
Darak
(@darak)
Hi all,
I can't find if this topic has been discussed before. I love the PrusaSlicer single nozzle color-changing feature(i.e., the printer will auto-pause on the next color change), and it will be beneficial to show the "time remains for the next color change" instate of the "total time remains" on display.
Not sure if I'm missing any settings? Or is this not a feature yet? Thank you.
Napsal : 16/05/2021 5:26 pm
1 lidem se líbí
RE: Display the time remains for the next color change?
devs don't watch the forums -- but a great idea to post over at github.
Napsal : 16/05/2021 7:07 pm
sca
 sca
(@sca)
I believe this functionality is in Mk3S firmware 3.10.0, but needs support from PrusaSlicer (2.4.0?).  From the release notes:
Until now, the firmware was only able to display how much time remains until the print is finished. There were multiple suggestions from the community on further improvements. Starting this release, the developers have implemented the first stage. However, to make the function work correctly, the PrusaSlicer dev team also needs to publish a new release because the G-code instructions must be updated.
Once both firmware and PrusaSlicer are updated, the "remaining time" will work the following way. The printer will switch every 5 seconds between "remaining-printing-time" and "time-to-next-color-change." Therefore the user will be informed in advance when the next filament change is expected.
Napsal : 16/05/2021 7:39 pm
@sca
That is very useful for MMU users.  I wonder if will work with the Mk3S alone.
Napsal : 16/05/2021 9:28 pm
Posted by: @cwbullet
@sca
From the way they've implemented it (a new parameter added to the M73 gcode) I don't see a reason why it shouldn't work without an MMU.
Napsal : 17/05/2021 2:08 am
It should do, here's the relevant gcode:
M73 - Set/get print progress M73: Set/Get build percentage
Usage
M73 [ P | R | Q | S | C | D ]
Parameters
P - Percent in normal mode
R - Time remaining in normal mode
Q - Percent in silent mode
S - Time in silent mode
C - Time to change/pause/user interaction in normal mode
D - Time to change/pause/user interaction in silent mode
M73 C   doesn't seem to be used right now but it's there...
M73 Pnn Rnn  is present all through the code and it's fairly simple to use it to extract a close approximation but as the only opportunity to postprocess is attached to the print, not the printer; it gets to be a chore to set up every time.
Napsal : 17/05/2021 3:07 am
@fuchsr
Thanks.  I can see how this would be useful.
Napsal : 17/05/2021 3:11 am
Ephram
(@ephram)
I was printing a thingy, and the display showed the normal R for time remaining.  It switched back and forth to a C, which led me to this thread.  The C is for time remaining, and prusaslicer on the MK3S w/MMU2 shows the time remaining.  I searched through the gcode for that one print, and there are periodic updates for both R and C values throughout the code.
I know this is an old thread, and you all have probably figured that out by now, but just in case someone arrives here like me, I hope it helps.
Napsal : 30/01/2022 11:24 pm
AnneVanLeyden
(@annevanleyden)
Do you have to enable this setting somewhere? I am now using Prusaslicer 2.6.0 alpha 6 and it does not generate M73 C/D. According to the change log, this feature was introduced in 2.4.0.
I have tried both with a simple color change on a certain layer and a virtual multi-extruder setup for manual filament change (I have no mmu).
This post was modified před 3 years 2 times by AnneVanLeyden
Napsal : 18/05/2023 10:30 am
AnneVanLeyden
(@annevanleyden)
Sorry, I didn't look right. When doing a 'simple color change on a certain layer' the M73 C/D code is in there.  But not when doing a multicolor print.
Napsal : 18/05/2023 4:04 pm
GiD
 GiD
(@gid)
Trying to Bump this back up.  My MK4S + MMU3 still doesn't show a time for Next Color Change.  Does the Code not have that information so it knows to Talk to the MMU3 and change filaments?  This seems to me like a fairly simple code fix.  Maybe not?  This would be super helpful to me knowing when the Printer is going to swap out filiaments...for many different reasons.  Doesn't it show you that information if you don't have an MMU enabled?
This post was modified před 1 year by GiD
Napsal : 16/12/2024 11:03 pm
hraftery
(@hraftery)
Something has changed. This worked out of the box with my MK3S+ without MMU. Either with PrusaSlicer's auto colour change feature, or by inserting colour changes manually in PrusaSlicer.
Many months, a few firmware updates and PrusaSlicer upgrades later, and I've noticed this week there's no "C" indication on the display any more. It says with "R". Yet the colour change action still takes place. Suddenly I really miss it, when I know there's a change several hours into a many hour print that I will have to wake up for, but can't remember when it's supposed to be!
Napsal : 19/12/2024 7:52 am
Sembazuru
(@sembazuru)
Posted by: @hraftery
This hopefully should be being fixed. I spotted this on the release notes for 2.9.0-beta1 (as of this writing 2.9.0-rc1 is available on github):
  • Fixed export of M73 C lines to G-code to fix displaying remaining time to color change. This was partially fixed in 2.9.0-alpha1 already, but not in all cases. #4734, #12849
I haven't experimented (generate some g-code and inspect in a text editor) yet so YMMV.
See my (limited) designs on:
Napsal : 19/12/2024 4:18 pm
hraftery
(@hraftery)
Ah! Good find. I noticed the link to #4734 is wrong. It likely should be the Prusa-Firmware issue, not an unrelated PrusaSlicer PR. The other linked issue only vaguely mentions "it has been fixed", so it took me some time to track it down. Looks like this is the fix. Which means this is probably the previous "partially fixed".
Looking forward to seeing this in the wild.
Napsal : 19/12/2024 8:52 pm
Sembazuru
(@sembazuru)
I noticed the link for 4734 was odd when copy-pasting the link, but I didn't take the time to figure out why. I was just copying from the release note. Glad you were able to workout their error.
Napsal : 22/12/2024 11:32 pm
hraftery
(@hraftery)
And it is! Yesterday I sliced a print in 2.8.1 and got no "time remains" indication on the MK3S+. I upgraded to 2.9.1, sliced the same thing and put it on the printer again - the "C" indication is back.
Unfortunately the diff between the gcode produced is not easy to read, because I positioned the STLs by hand so they're in slightly different locations. I had a quick look and there's lots of changes so nothing really stood out to me. What ever changed, works!
Napsal : 24/03/2025 11:11 pm
