Disable using same printhead when changing layers
Hi Everyone,
I need your insight, I am using prusaslicer to make prints with a cellink bioX6 bioprinter. In short I am using the equivalent of three different printheads, everything is fine for the first layer it uses the first, then the second, then the third. When he changes z he continues to use the third head (which is normal since it reduces the displacements) but I would like him to start again the same pattern as the first layer, that is to say first, second and third head ... is there a parameter on prusaslicer that would allow me to do this?
Napsal : 01/03/2023 1:32 pm
