Disable the Drop Table object function automatically!
SergioCSO
(@sergiocso)
Hello, is there a possibility to disable the object from falling on the table? I need to insert support but with the model at a Z height and I'm not getting it in Prusa Slider. Thank you!
Veröffentlicht : 26/05/2022 5:51 pm
Swiss_Cheese
(@swiss_cheese)
RE: Disable the Drop Table object function automatically!
@sergiocso
This should help explain.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/drop-to-bed-feature/
and another
https://forum.prusa3d.com/forum/prusaslicer/drop-to-bed-cannot-be-deactivated/
these two articles/threads should give you the information you need. the supports will probably be something you'll want  to discuss after  you figure this bit out.
However for supports , if your doing what I think your doing you will want to use Snug and for support enforcers only and paint on supports.
hope this helps
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 26/05/2022 6:33 pm
SergioCSO
(@sergiocso)
Hello. Thank you so much. I will do some tests following the recommendations of the topics. Thanks.
Veröffentlicht : 26/05/2022 8:06 pm
