Disable "feature type" aka Turn off infill or gapfill or internal perimeters
Box
 Box
(@box)
Hello all, I'm having some surface issues with a very thin walled object I'm printing.
at one section the wall which is mostly 2/3 lines thick has a bit of a bigger gap so Prusa Slicer is adding extra plastic in the form of another perimeter.
I've tried lowering it to just 1 perimeter butr then Prusa slicer just adds internal  infill, top solid infill, bridge infill etc etc
How can i tell it to NOT print a Feature type? I've tried setting its speed to 0 which seemed to work for gap fill but not for anything else
I'd rather it just have a small void inside.
Can't print in vase mode becuase I need the supports
Mask printed with surface bump showing
Settings I tried to 0 but this just added more internal junk
Este debate ha sido modificado el hace 4 years 2 veces por Box
Respondido : 19/09/2022 8:35 pm
R&D
 R&D
(@rd)
RE: Disable "feature type" aka Turn off infill or gapfill or internal perimeters
Gap fill can be turned off by either setting "gap fill" speed to Zero, or more recently there is a box you can tick to turn it off, I still use the zero method. Infill can be set to Zero. Another thing to do would be to un-tick "ensure vertical shell thickness" then scan through your model and see if you have any areas of "Internal junk" that you don't want. If you find any you might try setting "minimum shell thickness" for top and bottom layers to zero, if you still have areas where your seeing junk you don't want you can use either "Height range or shape" modifiers to remove the unwanted stuff only in the areas where you don't want it.
I don't have your project file so I can only make broad suggestions.
Respondido : 19/09/2022 10:44 pm
Box
 Box
(@box)
It doesn't look like I can attatch a project file to this forum so does this gdrive link work?
https://drive.google.com/drive/folders/1TY0apW8ihvtSJtNlWyd9puALtG589bA3?usp=sharing
I tried the settings you suggested but its still not leaving the inside gaps hollow but putting stuff inside
Respondido : 20/09/2022 3:07 am
Ringarn67
(@ringarn67)
Posted by: @rd
Yours was 100%!
Changes I made in your file:
Infill to 0%
Perimeters set to 1
Solid layers, Top and Bottom set to 0
I would change all settings back to default and start over, there is a lot of changes that make no difference
Posted by: @box
Forum only accepts zipped files
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Respondido : 20/09/2022 7:08 pm
1 les gusta
