Different top layer patterns for different items on same build
RedDawg
(@reddawg)
I would like to specify different top layer patterns for different objects on the build plate, not different instances of a given object. It seems I can modify many of the parameters for a given object, including layer thickness, fill %, etc,. but not top (or bottom FTM) layer patterns, or at least I don't find it in the various item editing drop-down menus. Have I missed it? Possible? If not, it should be. Off to github?
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Napsal : 30/08/2021 2:43 pm
I think you have missed it.  Top Infill pattern and bottom infill pattern are both available.  Click Add Settings>Infill.  The ones listed in the sections above Add Settings are the common basic ones(as decided by Prusa).  The Add Settings option gives many more.
Napsal : 30/08/2021 3:02 pm
1 lidem se líbí
Swiss_Cheese
(@swiss_cheese)
I'll add to that, you need to be in expert mode to see those settings.
The Filament Whisperer
Napsal : 30/08/2021 5:36 pm
RedDawg
(@reddawg)
Yep, missed it
I'm ALWAYS in Expert Mode, although I won't claim to be an expert (yet)! Thought I had been through all of the drop-down options, but I either missed it or didn't go deep enough (it's buried pretty deep). Thanks for the guidance.
Napsal : 30/08/2021 11:47 pm
