Different Bottom Fill Patterns for Different Parts in same Print
Ron Williams
(@ron-williams)
Im using a MK4S with MMU3, and would like some text in my model to use monotonic lines bottom infill, while the rest of the model uses archimidean chords.  Is there any way to do this?
Since the text is just 1.6mm high, I guess I could do a print of the text as a separate print and set my z hop to 2mm.  Would that work?
Veröffentlicht : 11/01/2025 5:19 am
RE: Different Bottom Fill Patterns for Different Parts in same Print
Yes.  This is pretty standard basic stuff.  You might want to go through the Prusa Slicer knowledge base in general but https://help.prusa3d.com/article/modifiers_1767 is the section on modifiers.
As long as your text is selectable, ie a separate Part then you can apply any of the modifiers to it.  Select it on the right hand tree list, and use Add Settings>Infill and then select Bottom Infill pattern.  The modifiers listed under Infill or Layers and Perimeters for example are just the common ones.  Using the add settings option you get access to many more.  You do have to be in Expert mode to see everything though.
Veröffentlicht : 11/01/2025 2:22 pm
