Defining small feature extrude path?
I have a mesh-like surface of small circular openings, and the way PS currently defines the path is to draw the circles and smear some infills in between. Because the features are small, this causes havoc and a lot of potential failures on first layer. Is there a way to change the way the slicer determines the path, and reduce the number of retractions and starts?
RE: Defining small feature extrude path?
Could you save the project as a project file, in Prusa Slicer (File>Save Project as>) then zip compress the resultant .3mf file, and attach the zip file to your next post?Please
Absolutely, thanks Joan - see the attached.
try this
basket jt
another option is a smaller nozzle
