Cutting in the X-Y plane
RedDawg
(@reddawg)
Cutting a model in the Z axis is relatively straightforward.  Is is possible to (easily) cut out sections of a model while in the X-Y plane?
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Publié : 02/09/2021 5:43 am
The only way to do that (at the moment) is to rotate the part and then use the normal cut function then rotate it back.
Publié : 02/09/2021 9:15 am
RedDawg
(@reddawg)
Yes, I had sort of realized that, although it would be cumbersome in some cases. Say I had an STL file of a 4 x 4 array of similar but slightly different objects, on a common base, not individually selectable, and I need to remove one on a corner, leaving the others. Maybe I could add a part consisting of a box with 0% fill and no perimeters that surrounds the one object I need removed? I'll have to experiment a bit.
Publié : 02/09/2021 12:16 pm
Sean Kane
(@sean-kane)
RE: Cutting in the X-Y plane
In 2025, it is possible to rotate the cutting plane, but holding down shift to draw a new cutting plane appears to work as well.
Publié : 14/05/2025 9:59 pm
