Custom the origin frame in prusa slicer
Rodrigue Richalland
(@rodrigue-richalland)
Hello,
I need to move the origin frame in prusa slicer for my own core xy printer. Exactly i need to rotate the frame at 180° one y axis.
Do you know how i can do it ?
Thanks
Rodrigue
Postato : 09/10/2022 9:17 pm
RandyM9
(@randym9)
RE: Custom the origin frame in prusa slicer
I don’t understand the question.
You can rotate any object you place on the build plate in PrusaSlicer to any desired angle.
You can also center, or move the object(s) to any location in the build space.
Does that not give you the results you require?
Cheers
Postato : 11/10/2022 4:34 am
Rodrigue Richalland
Hello.
My question is: Is it possible to rotate the origin frame of the build plate ? Thanks
Postato : 11/10/2022 2:22 pm
