Custom Supports
I would like to print a drawer where I am sure at least the top of the handle needs support
If I activate supports it will print me support which goes from print plate on which is a waste of time and material.
Is there any way to influence the origin of the support? I would like to have organic supports which goes only from bottom to the top of the handle like shown in the picture below
If yes how can I achieve that?
Thanks for your support!
Cheers, Michael
RE: Custom Supports
I had the same question long time ago and got help: https://forum.prusa3d.com/forum/prusaslicer/cannot-block-supports/
RE: Custom Supports
Thank you
Not sure if the solution is to change the first expansion layer to zero? In my case it didn't change anything. Or do I need to combine it with support blockers?
Whatever I do the support grows from print plate and I only want to have it with the handle, organic support type if possible. Any idea?
