Custom printer - Creality STL visual model not match
juanpa
(@juanpa)
Hello,
I use PrusaSlicer with my Creality CR10S Pro. I tried to add the printer model STL but the bed is outside the printer.
I took the model from Cura. How can I fix it ?
Thanks
Publié : 29/03/2020 1:18 am
Sembazuru
(@sembazuru)
RE: Custom printer - Creality STL visual model not match
I came across a similar issue with the Lulzbot Mini bed model scavenged from the Lulzbot edition of Cura. I looked at the settings in Cura and there was an xyz offset setting for bed models in Cura so apparently Lulzbot didn't need to fix this. But PrusaSlicer (was 2.1.1 when I was doing this) doesn't appear to have an xyz offset setting for bed models. I used Meshmixer to load the bed model stl and used that to change the origin (moved the model in Meshmixer and saved out as a new stl). To guide me on how much to move the stl I counted the squares as seen in PrusaSlicer (the default bed texture squares in PrusaSlicer are 1cm squares).
(Unfortunately, I lost that file in a computer upgrade...)
See my (limited) designs on:
Publié : 29/03/2020 2:45 am
juanpa a aimé
Gungriffonbr
(@gungriffonbr)
i have same problem too i was trying to insert a delta model hehe
Publié : 29/03/2020 2:50 am
Vojtěch Bubník
(@vojtech-bubnik)
Membre Admin
Center of the print bed texture is aligned automatically with the center of the print bed I believe.
We have an issue open for it, you may find an explanation there.
https://github.com/prusa3d/PrusaSlicer/issues/3798
Publié : 29/03/2020 10:34 am
juanpa
(@juanpa)
Thanks to all for your replies
@sembazuru
This is what I finally made, thanks a lot for the tips 😉
Publié : 29/03/2020 11:20 am
Sembazuru
(@sembazuru)
Posted by: @bubnikv
the issue here isn't the print bed texture, rather the print bed model.
Publié : 30/03/2020 3:20 am
juanpa a aimé
