Custom G-code to show Layer height
hackebike
(@hackebike)
Hello,
I would like to set some Custom G-code to show Layer height inside the exported G-code.
What is the syntax to be used?
thx
Respondido : 22/10/2019 10:00 pm
Nikolai
(@nikolai)
RE: Custom G-code to show Layer height
In the default configuration there is already a comment placed with a line number.
Do you want to have additional comment line in gcode or do you want to display something special on screen during print (based on the layer height)?
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 22/10/2019 10:11 pm
hackebike
(@hackebike)
not line number, I am looking at generating G-code which has the layer # for each layer block, so that I have a reference of each layer in G-Code.
I would like to add code in the Custom G-code section that generates the above info into G-Code.
thx
Esta publicación ha sido modificada el hace 6 years por hackebike
Respondido : 23/10/2019 2:30 pm
