Custom G-code: Current Position Placeholders
Kremnari
(@kremnari)
Membre
Greetings all,
I have been building a Multi-Extruder Single Hotend solution for my printer.   I have it working by using a switch placed at Y-max, but now I need to figure out the g-code.  Sadly my firmware doesn't support G60/61 (Save/return position).  Before I got trying to rebuild the firmware, I am curious if there are custom G-code placeholders in PrusaSlicer for current position?  My hope would be to switch to absolute mode, move to Y max, and the return to position_placeholder
Thank you
Kremnari
Publié : 07/04/2024 1:34 pm
Eef
 Eef
(@eef)
RE: Custom G-code: Current Position Placeholders
Would love to see some pictures!!
What about using G92 to create a second "Home" to goto ? (PS. I do not completely understand what your what to achieve, so I am a but guessing 😉
Publié : 07/04/2024 9:51 pm
Kremnari
(@kremnari)
Membre
I was trying to avoid rebuilding my firmware, I removed that constraint and it all fell into place.  In recompiling, I enabled saved positions and debug pins.  The board I'm using is the Creality 4.2.7, which has two available pins on a unsoldered 4pin header.
I'll work on a YT video to showcase it and link it back here soon
Publié : 07/05/2024 1:08 pm
