Crash slicing large objects using hilbert curve
KeeganPelton
(@keeganpelton)
I've run into a problem when slicing large objects using a hilbert curve for the top and bottom fill pattern. I like to use it on smaller parts because it tends to turn out better than monotonic on my MK3S. Sometimes I'll just accidentally leave all the settings the same (shouldn't be a problem) when printing bigger parts, but trying to slice large objects like the example linked just leads to a PrusaSlicer crash. Switching to monotonic pattern solves this issue but I am curious as to why the hilbert curve doesn't work on large objects.
Example object
Este debate ha sido modificado el hace 5 years por KeeganPelton
Respondido : 22/07/2021 1:22 am
Theres a known issue with hilbert curve.  This github post https://github.com/prusa3d/PrusaSlicer/issues/6470 about an issue with Archimedean has a post at the bottom "I hoped the issue was similar to the Hilbert curve issues we fixed in the upcoming PrusaSlicer 2.4, "
Respondido : 22/07/2021 8:24 am
KeeganPelton
(@keeganpelton)
Good to know, thanks Neophyl. I'll keep an eye out for the 2.4 release.
Respondido : 22/07/2021 5:53 pm
