Copying Print Settings to a different printer
I changed my printer settings (different nozzle) and print settings at the same time then saved both, it saved the print settings under a different printer.
How do i copy those print settings / change them to the different printer as they will only work with the 1mm nozzle?
Edit: Changing the "Compatible printers" to be the 1mm nozzle version worked!
Ce sujet a été modifié il y a 3 years 2 fois par Josh Wood
Publié : 13/09/2023 3:56 pm
