Controlling everything with the volumetric flow rate in 2.6
jb2022
(@jb2022)
Hello at all!
I have a general question about the point of view controlling everything with the volumetric flow rate inside the Prusa Slicer 2.6.
The volumetric flow rate is a product of layer height, extrusion width and print speed. Why is the percentage extrusion width caclulation, based on the layer height and not the nozzle diameter? I change every print the layer height, depending on the printed model. But I swap my nozzle less frequenter!
Should I have for every layer height a print settings profile? Really?
OK, I don't use dynamic layer height, but I want the maximum speed based on my volumetric flow rate.
In best case I configure a percentage speed (where 100% is the calculation), calculated from the extrusion width (in percentage of the nozzle diameter) and the layer height.
Is this approach in any ways currently possible? Miss understood I something?
Please help!
Kind regards J.
Veröffentlicht : 10/04/2023 1:52 am
