Confused about "Supports" the AUTO setting
[Rozwiązany] Confused about "Supports" the AUTO setting
raymate
(@raymate)
The default is "Auto Generate Support" and its checked but its not detecting overhangs what am I missing.
If I enable "Generate support materials" it then works.
Am I just reading that wrong? the default seems to be no supports?
And you need both option checked ON?
Prusa Mini+ (Ordered Dec 19,2020 - Arrived Feb 21,2021) stated clicking Mar 2nd / MP Select Mini V2
Opublikowany : 25/02/2021 2:53 am
egar
 egar
(@egar)
RE: Confused about "Supports" the AUTO setting
Correct, by default no supports.  You have to enable the "Generate support materials" option.  I too found it confusing to have to select both options.  Now I've just accept it and enable when needed.  Default settings work pretty well for me, but there are endless examples in the forum of tweaks to optimize supports.
Opublikowany : 25/02/2021 1:27 pm
1 ludzie polubili
raymate
(@raymate)
@egar
Pleased it wasn't just me. Understand it now. Thank you. Im new to Prusa and Im coming from CURA. Prusaslicer is much faster than CURA which I like a lot 😀
Opublikowany : 25/02/2021 1:49 pm
