Configuration Wizard Problems
deibner
(@deibner)
Hi,  Just loaded 2.2.  When I try to add printers it opens the Configuration Wizard and I can select the items I want to place on the pull down menus but when I hit finish it doesn't save the selections.
Any ideas?
Veröffentlicht : 10/08/2020 9:05 pm
RE: Configuration Wizard Problems
You will have to provide more information than that.  Is it not saving all ?  Is the wizard completing but not everything is there after the wizard completes ?  Detail needed.
For example when working through the wizard what printer(s) have you selected ?  Filaments etc.
One thing to bear in mind is that once installed not everything is visible by design.  For example if I install a MK3s printer and also a MMU2 printer (so 2 types) and then install all the filaments then after the wizard if I select the mk3s then most if not all the filaments I installed will be available.  If I change my printer to the MMU2 one then some of the filament options will disappear as they not match the restrictions placed on them as Prusa has decided that those filaments arent compatible with the MMU2.
Hence my question of what have you selected for the wizard ?  I should also point out that the vast majority of the filaments available are part of the Prusa vendor space and so will only show when you have a Prusa printer selected as your active printer.
Veröffentlicht : 11/08/2020 9:53 am
