Component print requires unloading/reloading filament every couple of layers, for no good reason?
steveH
(@steveh-3)
After a little time away from printing (life/work sometimes gets in the way), I decided to print a filament spool holder that better fits my needs. So far, so good. I chose graham01's anti-tangle spool holder (Thingiverse thing:2479238).
The stl files seemed fine, PrusaSlicer ate them happily, and put out gcode files to print.
Everything went swimmingly, until the upper two cross beams ("sh arm cross beam top v1"). Most of the other pieces printed in two colors; no problem. Unload, switch, reload, continue...
The upper arm cross beams seem to want to switch filament every layer, maybe every third layer. One loses count.
I can't see anything that would cause it in the stl file (using FreeCAD), nor in the generated gcode. Anyone have any idea of cause, a fix, or a workaround? I can't even find any instances of filament change-related Gcodes in the gcode file, which doesn't mean they're not actually hiding there.
Any ideas?
PrusaSlicer : Version: 2.1.0+
Build: PrusaSlicer-2.1.0+-201909160907
Prusa i3 Mk.3, firmware 3.8.1 MK3
MacOS 10.15.2 (Catalina)
Este debate ha sido modificado el hace 6 years por steveH
Respondido : 04/01/2020 2:54 am
RE: Component print requires unloading/reloading filament every couple of layers, for no good reason?
Could it be false triggering of the Filament Sensor?
try again with the sensor turned off
Regards Joan
Respondido : 04/01/2020 9:36 am
steveH
(@steveh-3)
@joantabb
Might could be. Although it's the only file that behaves that way, and different filaments don't behave differently.
I'll give it a try when I get some time.
Respondido : 04/01/2020 4:21 pm
steveH
(@steveh-3)
That turned out to be a useful workaround. Whatever the cause of the innumerable filament reloads, turning off the sensor ignores them, and the pieces look to be printing just fine.
Thanks again for the workaround.
Now to figure out what triggered the problem in the first place...
Respondido : 04/01/2020 11:37 pm
is this mk3, or mk3S?
Joan
Respondido : 05/01/2020 1:39 am
steveH
(@steveh-3)
@joantabb
Mk3, as mentioned in the OP; haven't upgraded yet.
Respondido : 05/01/2020 3:32 am
@sehix
the Mk3 with the original filament sensor suffers from a couple of issues,
it can accumulate Dust in the sensor chamber, there is a port on the right hand side of the extruder that allows you to insert an Air Duster pipe and blow the dust out...
this port should be covered with a small block of plastic... if the plastic is missing, light can get in and upset the filament sensor...
also the sensor tends to get upset by clear filament, translucent filament, Shiny filament and green filament... apart from that' it's quite a good sensor...
some people update the extruder to use a ball bearing between the filament and the sensor like this https://www.thingiverse.com/thing:3223513
Respondido : 05/01/2020 10:39 pm
steveH
(@steveh-3)
@joantabb
Mine has all the bits in the right places. It just happened that that one single model showed the behavior noted. Every single other one I've printed has been just fine, including every different filament I've loaded into the innocent machine.
There's almost certainly something pathological with the stl model, or the gcode derived from it.
A most useful workaround, in any case.
Respondido : 06/01/2020 12:30 am
