Compiling latest source, pressure equalizer missing...
errolt
(@errolt)
Hi All,
I have to compile PrusaSlicer from source, as the Anycube MonoX printer profile isn't included in the official release. (Any idea when it will be included officially?)
When I build the latest master branch(V2.6.0-alpha0), the Pressure Equalizer option is missing. How do I include it in my build?
Thank you,
Errol
Opublikowany : 21/09/2022 3:21 pm
jsw
 jsw
(@jsw)
What build platform are you using?
As a sanity check I just updated my source tree to 2.6.0.a1 and got a clean build which executes without errors.
This would be on a recent Ubuntu 20.03.
Opublikowany : 22/09/2022 12:55 am
jsw
 jsw
(@jsw)
RE: Compiling latest source, pressure equalizer missing...
Oops, my bad. It's a0, but the edit window expired.
Opublikowany : 22/09/2022 1:08 am
errolt
(@errolt)
I'm building on Ubuntu 20.04.3.
It builds fine, and runs fine.
But the Pressure Equalizer settings are missing. The speed properties screen ends at "Auto Speed", where as there should be a "Pressure Equalizer" section under "Auto Speed".
I don't know if it is related, but I see this error on the commandline that I ran PrusaSlicer from:
[error] Could not find property tree in version file. Checking for application update has failed.
Opublikowany : 22/09/2022 5:40 am
jsw
 jsw
(@jsw)
Ok, I misunderstood.  I thought it was a build error.
I get the same error message when I launch from the command line.  I have never used those features.
This issue would be better brought up over on github than here in the forum.
Opublikowany : 22/09/2022 9:39 am
errolt
(@errolt)
Thank you for trying to help.
I wanted to ask here before I pollute the git issue list.
Opublikowany : 22/09/2022 3:33 pm
1 ludzie polubili
